Korean Kia Stinger badging can be added to US, Canada and Australia models
StingerMike
Just came across a post on FB where a member in Australia swapped out the front KIA emblems for the E badge as well as swapped out the rear for the larger Stinger badge. The only issue he had was that the outline of the old emblem was still visible. I believe you can easily remove that with a bit of wet sanding.
Note: You have to trim down one of the pins in order to make them fit as the backs are different.
Part# 86330 J5100, 86330J5100, 86330-J5100
Dominic Rob?rt said:
Getting close now .... the dealer has fitted the "E" badges, and the new wheel caps.
Only issue is that the Kia badge on the front has left a faint outline of where it used to be, the E badge is smaller. The dealer says it won't polish out. I can't understand how that can be .... will go check it out before they prep the car.
Anyways .... loving the big Stinger emblem on the boot.
Not long now
Dan
2015 Acura TLX
That's great news.
Just looked up the parts needed.
OEM Kia Stinger Front Nameplate Emblem - 86330J5100
OEM Kia Stinger Rear Emblem Nameplate - 86311J5000
StingerMike
StingerMike
Just a heads-up there are indeed holes underneath the rear KIA Badge, so the STINGER emblem will not work.
IN
2018 Kia Stinger GT2, 2004 MSM
Just put a little clear silicone in the holes and make sure the Stinger script badge covers them up.
IN
2019 Blue Stinger GT2
I want to black out the top like Range Rover. Does anybody know where replacement parts be ordered? I need to get a black antennas
No need to get a replacement top or antenna. You can have the top and antenna wrap in black vinyl
IN
#8
IMG_0383.jpg Yes but these strips have a white rubber seal. I need to get black ones, so I thought it would be easier to get the black antenna at the same time
No need. A reputable vinyl installer will be able to cover those seals and antenna without issue. I am having mine done this coming weekend.
Not my car, but you can use as reference.
