Stinger ECM PIDs
I'm currently using the Torque Pro App with a cheap ELM327 OBD II adapter to read the boost and coolant temperature (and 0-60 time). Was wondering if any of you tried to see what the extended PIDs are yet - particularly engine oil temp. The "generic" engine oil temp PID doesn't work.
On a side note, Torque Pro + Android Auto + OBD2AA = Boost gauge on the center screen! It's pretty great.
Bahrain
2011 - 997.2TT
Very interesting, I was looking into the available OBD2 readers online yesterday.
What a parameters are you able to log other than the boost etc?
Also what is the peak boost you are getting.
E
I'll have to check for the full list later, but off the top of my head I can get most of the "normal" pids - coolant temp, boost level, throttle position, engine load, engine rpm, ambient temp, intake temp, intake manifold pressure, etc.
The maximum boost I've seen (haven't actually fully floored it due to rain where I am) is 11.8 pounds of boost.
Edit: Just checked again, I think I saw 13 lb briefly.
United Kingdom
2010 Jaguar XF 5.0 V8
Torque can log to a file so you can review maximums later.
2018 stinger GT2 AWD
PIDs that are needed specialy when modding is knock and timing
