Greddy Blow Off Valve for the Kia Stinger
Crock89
CT
If you are upgrading the turbos then this is a must have and Don't care ablut warranty. If you are doing it for the sound get a cai. Keep in mind doing a modification that associates with the turbo WILL void your warranty if later down the road you have issues with oil leaks shaft play or defective turbos....
Crock89
CT
You should mention to all that this product voids warranty! save your money it should be noted and be known! If you plan on upgrading the turbo by all means it's a must have. I believe everyone has a right to know!
I wants!!!
[MENTION=291]MurlinatoR[/MENTION] Does it really void the Warranty?
I wants!!!
Ooooooo..... this one would be questionable. If it controls the boost properly, maybe not.
If they cause a problem with the engine then they won't cover it. That's how most "add on" mods will go.
Crock89
CT
Perfect example few years back I went in to Subaru with a problem related to too much oil being consumed. Turned out it was a turbo seal on my stock wrx sti and I got denied warranty because I had a boost gauge attached to a vacuum line. Dealers find anything to make money remember that. Lesson learned. just be cautious
Good thing this is just a blow off valve and does not control boost, it just lets out the excess pressurized air when decelerating.
Great find [MENTION=420]TuscaniCustoms[/MENTION] but that is one expensive adapter kit.
I'm guessing it will be close to $500 for the kit and the BOV's correct?
Slovenia
Hyundai tiburon 2.0L 2006
Price with shipping included for adaptor kit is USD $ 220.29 and keep in mind there are two adaptors and two valves, not just one as usual. I don't know how much HKS valves are but you can check yourself with this part number 71008-AK001 Those adaptors are made from aluminium and it looks like they are machined so I imagine that's why they are expensive. Everything is doubled with 3.3T engine.
2018 Kia Stinger 2.0l Premium
The 2.0 adapter flange I have does not fit! Lol From Sxth element. The flange for the 3.3 is rectangle, this one is off set lol
Firemedix - Lakeland, FL
Thread Starter #18
LOL did you ask the seller why they sent you the 3.3 adapter?
