Kia Stinger Wheel Size, Bolt Pattern, Offset & Tire Information
South Korea
Kia Stinger
Stock Kia Stinger Wheel Information:
8.0J?18
8.0J?18
8.0J?19
8.5Jx19
18" Alloy Wheel (A-type)
18" Alloy Wheel (B-type - Premium Models)
19" Alloy Wheel (A-type - GT Models) #52910-J5220
19" Alloy Wheel (B-type - GT Models) #52910-J5210 (19x8), #52910-J5260 (19x8.5)
Kia Stinger Hub Centric Ring:
67.1mm Hub Centric Diameter
Kia Stinger Wheel Weight:
19" - 34lbs
Standard Kia Stinger Wheel Offset:
18" A-type - 34mm
18" B-type - 34mm
18" - 40mm
19" - 40mm
Depending on the wheel, you can go with an offset from 34mm to 42mm.
Kia Stinger Tire Sizes:
Michelin Pilot Sport 4 225/40/R19 & 255/35/ZR19 (Included)
Continental ContiSportContact 225/40/ZR19
Bridgestone Potenza RE97AS-02 225/45/R18 & 225/50/R17
17" Tires
225/50/R17
18" Tires
225/45 R18 (Recommended)
19" Tires
225/40 R19 Front (Recommended)
255/35 R19 Rear (Recommended)
Tire Pressure
18" - Cold
Front 225/45R18 - 36psi
Rear 225/45R18 - 39psi
19" - Cold
Front 225/40ZR19 - 36psi
Rear 255/35ZR19 - 36psi
19" - Cold
Front 225/40ZR19 - 38psi
Kia Stinger Spare Wheel & Tire Size:
17"x6"
Kia Stinger Bolt/Lug Pattern:
5x114.3 or 5x4.5
Kia Stinger Tire Pressure Sensors TPMS:
Ford Part# 52933 J5000
Kia Stinger Aftermarket Wheels:
https://www.kiastinger.org/forum/threads/118-Kia-Stinger-Aftermarket-Wheel-Options
2013 Rio
I didn't see any info on the 18' GT Style wheels. And if you are getting a GT2 while style GT wheel is going to be on the car?
Robs
Member
Singapore
Just got my Stinger and discovered that the stock 18? Type B wheels have an offset of 34!
JJay03
I can verify today at the dealer but im guessing the Stinger GT2's that comes with all seasons are 225's in the front and back?
Kia Stinger GT2 RWD
Has anyone replaced their stock GT tires? If so, what did you go with and from where?? Only have 7K miles on mine so far, but figured I'll need a new rear pair soon enough... Thx!
The 19x8.5 US-version rear wheel has a 46.5-mm offset.
2019 KIA STINGER AWD GT1
Anybody considering steel wheels for a winter tire set up? I found these that might work.
https://onlywheels.com/wheels/steel-wheel-18?cid=1279,1281,1282
Since these steelies are an inch narrower at 7-inches wide, instead of the stock wheel's 8-inch widths, would I need to downsize to narrower tire from stock too? Or would you just shoehorn the stock 225's onto the 7-inch wide rims?
My winter wheels and tires order just got cancelled, so back to square one - still looking for a winter/wheel setup...
